Need suggestions on exhaust
Raj
Standard Bore
Rocket 3
Hi guys,
I am new to this forum..I live in cental PA and ride 2014 r3 roadster..I am planning to change my stock pipes..The local dealer says there are not many for rocket3..Can you guys sugest me any place where i can buy some slipon pipes which sound good for the rocket..
Thanks and appreciate the help..
Raj..
Unless you want to do the entire system including the air box, header, crossover and pipes from Carpenter, CES, or a used set of Jardines; I would look for a new set of Triumph factory TORS for the Roadster and install the new tune.
Here is the part number===> A9608077
Throw that number into google shopping and look for the best price.
Just my .02
S/F
B
You could contact @Paul Bryant aka Viking exhaust, I think he offered to make some slip on for another member, but I could be wrong. Either way Paul seems like a good guy and I'm sure he can help you.
To contact a member hit the icon that looks like a envelope, top right hand corner just below the front tire of the roadster. Put the members name in and send him a message. FYI hope this helps.
Thanks for the reply sir..
I looked for the part number and the pipes look almost like stock..
Do you know if they sound any better..
Thanks..
They look stock, they are not. TORS stands for Triumph Off Road Silencers, and they are intended for track / racing use. They are lighter, flow better, add HP and run cooler / louder; however, they MAY not pass the DOT emissions / noise requirements. You will also need to download a new tune to adjust the air / fuel mixture. You dealer can do this for you for free if they do the swap, otherwise you can do it yourself with a cable and a laptop...
Just a FYI
S/F
B
Raj, see my face book page www.facebook.com/vikingexhaust or if you have or find a photo of what you would like, show me and I'm sure I could build it for you.
Reactions: Jag
Thankyou sir..that helps alot..let me take this part number to my dealer and ask him to order and istall it..
