sixpack
New Brunswick Canada
:( The bike mounting bracket and the stock muffler won't line up if muffler is attached to cat delete?? I tried many combinations (loosen this, loosen that :confused: ) is it possible the the oem cat must be used for stock muffler?? I think that whoever installed the TORS cross threaded the mounting bolts also, now another problem:eek: any ideas?? anyone..
No. I had cat delete (Staintune) with standard mufflers for a short while before I fitted TORS and I know plenty have used Triumph cat delete with standard mufflers. Are you sure you don't have your mufflers mixed up?
I have the cat delete with stock muffs....
They are a little tricky, but there is DEFINITELY a specific arrangement. I had to fiddle with the two on the right side in order to figure out which one went where.
I suggest leaving all of the bolts very loose until you get everything lined up. There needs to be some 'play' in the joints for the pipes to line up. Get all of the bolts started before you start tightening anything down.
Sorry I can give much more guidance.
:D you guys were right on... mufflers mixed up... real easy when you got things right:) doing 12 min. tune right now, then off to the dealer tomorrow to check and balance throttle bodies.... thanks everyone!!!
