Well, it appears I wasted $35 on the universal adaptors. As it turns out, they don't fit the Rocket mirrors...I guess I'll have to try washers under the nut...
grampi,
The mirror stems come out past the bottom of the mount point just a bit.
When you tighten the bottom nut it can't pull the stem tight enough and the stem swivels.
When you add washers under the nut, the washer center opening must be larger than the mirror stem bottom diameter so the stem can be tightened downward into the center of the washer.
If the stems were just a bit shorter the problem would not exist in the first place.
Grampi I went with a split stainless steel lock washer (with a large enough ID to go around the stem) their pretty thick so when you tighten the bolt and compress the lock washer it was still thicker then I needed and it gripped well.
