xhdskip
Recall: 2008 Rocket III Touring - Wrong Certification Label
Make / Models : Model/Build Years: TRIUMPH / ROCKET III TOURING 2008
Recall Number: 08V145000
Summary:TRIUMPH IS RECALLING 356 MY 2008 ROCKET III TOURING MOTORCYCLES FOR FAILING TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 120, "TIRE SELECTION AND RIMS FOR MOTOR VEHICLES OTHER THAN PASSENGER CARS," AND PART 567, "CERTIFICATION."
THE CERTIFICATION LABEL, LOCATED ON THE LEFT FRONT FRAME TUBE, INCLUDES INCORRECT INFORMATION REGARDING TIRE SIZES AND PRESSURES, AS WELL AS AN INCORRECT GROSS VEHICLE WEIGHT RATING (GVWR).
Consequence:AN OWNER MAY UNDER-INFLATE THE FRONT TIRE IF USING THE INCORRECT INFORMATION. UNDER-INFLATION MAY CAUSE A TIRE TO SLIP OR COME OFF THE RIM CAUSING A LOSS OF CONTROL WHICH COULD RESULT IN A CRASH.
Remedy:DEALERS WILL INSTALL A NEW CERTIFICATION LABEL. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT APRIL 4, 2008.
OWNERS MAY CONTACT TRIUMPH AT 1-678-539-8782.
__________________
SPEED SAVES©
__________________
SPEED SAVES©
