Instrument Cluster Movement – Anyone Else Experiencing This?
Koki_999
Beer or not, the road ends the same.
Czech republic Prague
ROCKET STORM 3 R 2025
Hey everyone,
I have Rocket Storm 3 R 2025 and have noticed that the instrument cluster moves vertically depending on acceleration and braking. I took it to the service center, where they tightened it, but even after that, it still shifts while riding.
Has anyone else experienced this issue? If so, how did you fix it?
Thanks in advance!
I had this issue after my replacement cluster was fitted. The ' technician ' tightened the bolts on the side (pic 1) to shearing point. I loosen off those and gave the underneath one a squeeze then tightened up the outer ones again. Obviously there was no laptop for the 'technician' to plug in to fix it so I had to do it myself
It shouldn't do that if the screws are tight on each side of the mounting bracket.
Perhaps there is a washer/spacer missing?
I can't remember the assembly in detail, but I know the principle of how it is fixed.
One word of caution....if the cluster is so loose that it can bounce up and down easily when you hit a bump in the road, the stress shock could damage the cluster housing. Something to take care about.
