Jardines?
Very nice lifter, ballyono. What was the cost for that?
By any chance would you have a lnk to another German fabricator who makes all sorts of parts for the R3, like radiator inserts, chin spoilers, handlebars and clamps, etc? The company I'm thinking of make s at least 2 dozen different custom bits for the R3. I'd appreciate any help you can render!
try " edelsthal V4A " from germany
the guy make absolutely the best accessories for R3 and it is quality. I saw it with my own eyes in germany this summer I mean last summer
That's exactly the site I was referring to, Duke. Thank you kindly!
Jardines
Thanks Guys,
Also have a look at www.exactrep.com (UK) they make an very nice nice radiator insert and some other Rocket parts. Another Triump Rocket forum where you can find some links is a german one: www.rocket3.org
TriumPhil: The Lifter I mentioned is not cheap: in total roughly 600 euro but it works well and safe and is made out of rostfree iron. But again to go to the the States means transports, imports and VAT.
Triumphil,
The Kern-Stabi Lifter out of Germany ( with the special mount plate for the Rocket) arrived and was easy to install. The quality is very good.
When lifting the Bike it stands very steady and safe.
I have a Trunl placed and while lifted the hindwheel stays on the Floor.
When you push the the Frontwheel down ( which goes easy) the hindwheel comes off the floor. It is also very easy the replace the Bike when lifted if you have the wheels installed as well.
Again to get it in into your place wil cost some Bucks and for that amount there will be other solutions?
Regards,
Hans
( ps. dank je wel, which means thanks are three words )
Triumphil,
Dank je wel for all the info, Hans!
In the spirit of proper international linguistics, I should point out that the only things we Americans refer to as being "hind" are rear legs and/or teats on quadrapedal mammals, never for the rear wheel set!
Touring on the Dynojet
Today the Touring went to a tuningstation for severall runs on the Dynojet with the Tuneboy software..
After having installed the Jardines the sound was just to Loud for me but Jardine does not make DB Killers so I asked help in the tuning station. In an half hour time they produced a pair of killers theirself, top.
The sound is a lot better know which also makes the wife happpier.
Without the killers they took the bike to 156,5 Bhp at 5400 rpm and a torgue of 230.1.With the db killers at became 152.5 Bhp at 5461 rpm and 225.8 torgue.
They also maximised the speed at 225 km per uur max ( was 200 km) and they calibrated the limiter so it shows the exact speed.
The engine was running far to lean when a came which can cause serious damage at high speeds. So I am happy that I took here today for a Dyno Tune.
One special thing the Tuner said was the following:
It had not been necessary to remove the original air filter and the secondaires and removing the Lambda sonde was also not necessarry. He would have been possible to get it almost to the same specifications without all that been done!!. All these things can be adjusted with the Tuneboy software. Secondairies, Lambda sonde etc.
Getting more air in could be done by removing a kind of plate underneath the Saddle which is sufficient enough to give it enough air.
Better could have brought it earlier before all these changes.
So all I can say: If you change some things on the engine, bring here to a station who knows how the Tune it on a Dyno Jet. This will bring the maximum out of it and shurely gives you a good feeling.
I will put a piece of film on Youtube in a few days for those who are interested.
For thosse who have Jardines and have problems with the loud sound: look at their sire, snd them a mail because they can make a set of Killers and set it to you:
Tovami: testbanken voor motoren, auto's en karts sorry but is in Dutch only.
regards,
Hans
Netherlands
