Good morning...
I just ordered the Ixil pot for my bike. It seems correct to me and I hope the quality will be there !
I don't think I'll have it painted because my bike is red but you never know. I have a question regarding the reprogramming of the ECU : can any reprogrammer with a Dynojet type power bench access it and, above all, can they access all the parameters ? I also have an Indian Challenger on which the ECU is impossible to modify correctly...
Good morning...
Hi
All I can tell you that if you put the Ixil system on the bike without the baffles and an uprated air filter the bike will feel a little lumpy on start up but clears once it runs for a few minutes. You can do your own ECU reset( switch ignition on. Dont touch the throttle. Allow 3 fan cycles. Time 12 to 15 mins. Switch off.) No where within the fitting instructions does it say that if the end user does this they need to get a retune or remap to dial this all out. I would go for a complete remap as opposed to dynojet.
Tune ECU do this and also I have heard great results from Woolich Tuning who have had good results with their software.
My warranty expires next month and I have my Rocket 3R Black booked in with a well known experienced tuner who uses the Woolich software local to me who reassures me the bike will be nothing like you've experienced before. So I have had a good look around and asked questions and all the seasoned bikers have recommended this genius of a tuner. Look around your area and do some research first, then make a decision what's best for you.
Hi
👍 for your answer !
I actually saw that Woolich offered MAPS like BT. Which is the best ? I don't know but I'll ask the programmers on my island if they work with one of these two options.
👍 for your answer !
Ixil exhaust received yesterday and installed this morning. Nothing very complicated even if you have to force a little to have all the fixing holes aligned...The noise, without the db killers, is very acceptable (I expected much worse !) and started with a reset of the ECU (original air filter kept for the moment). Test scheduled for tomorrow...we'll see the results on the road !!!
Conclusive test even if I wonder if I'm not going to turn on the dB killers...the Ixil is impeccable at idle but as soon as you crank up the engine it gets really loud ! To see during the week !
Small clarification also: I don't know what the factory uses to make the silencers but... it seriously stinks!!! I hope this won't last because my garage looks like a skunk den.
Does anyone have a picture of the other side of the Rocket after the Ixil exhaust is installed? I noticed that Rockets with the Comp Werx installed have a large vacant area on the "port" side of the bike. Not a fan of that look.
Thanks!
Thanks!
Miles better finish with Ixil.
Hi Run666 did you remove your rear wheel and also did you need new gasket as I have received my exhaust with no instructions
