instrument panel replacement
This is the ecoroute by garmin. You can customize the gauges to show anything you want. the list includes speed, tach., coolent temp, intake man pressure, intake air temp, timing advance, battery, engine load, throttle position, oil preasure. I might be missing a few not sure. The layout stays the same with 5 gauges, but you can change what gauges show.
Works with many of the garmin GPS systems, and its bluetooth so there is no wires. little box plugs into OBD2 plug and fits right next to the battery where the plug is. also works as a engine light code checker and tracks miles per gallon instantly.
