Pig9r
Kansas City, MO USA
The other day I started my Rocket and it wouldn't fire. I had to hold the throttle open a bit to get it going and then when it started it wouldn't hold an idle. I shut it off, started it up and it was fine. I had just switched from triple unifilters back to triple K&N's.
This morning I went to fire up the Rocket and got the same thing. Wouldn't hold idle, got some after firing and back firing. It also back-fired through the intake bad enough it about smoked me off the bike. I shut it off and restarted it, the same thing, wouldn't hold idle. So I just gave it some gas and rode it for a few miles. After a few miles of riding it would then hold idle just fine. I have started it twice since then, and it seems fine. Once I was going, it never misfired and it felt just as strong as before, just wouldn't idle.
Does this sound like a TPS issue? It is an '06 classic, original battery. I haven't checked any vacuum lines yet.
Brian,
it doesn't sound like a TPS issue.
When you say it wouldn't hold Idle,
was it idleing up between 2,400-3,200 RPM's?
Mine would start and immedeatly go to 3,000 RPM's.
When riding and downshifting,
it wouldn't come down below that 3,000 mark,
unless I brakes her hard and almost lugged the motor down,
then if I stayed on the brake, it's come down for turns or downhill.
then as soon as I'd let off the brake she'd go back up to 3,000-3,200.
