Heated gear/current battery draw?
Im curious about heated gear. How do you hook up pants, vest, gloves and socks all together? I see that they each have a cable, but can they all be daisychained together to make it so that you only have to plug 1 thing in? or do you have to have a seperate plug for each item?
I have the heated vest, sleeves and gloves from this place, all high quality and yes everything is daisychained together and comes out as one plug. They are in Richmond Hill you can buy directly from them and get a discount if paying in cash.http://www.gearscanada.com/heated-clothing.html
Hence the value of installing the Eastern Beaver bypass kit, or equivalent. Run whatever bulbs you want on your own wire, and leave the Triumph wire to handle the little stuff.
The Eastern Beaver kit does not help with the auxiliary light wiring. I had the kit installed early on and still fried the wiring. Unless of course you're talking about replacing the wiring harness for the auxiliary lights. That would also involve replacing the wiring in the factory loom as well.
