atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 3,126
- Location
- Keller, TX
- Ride
- 17 T-120 Black, 20 Bobber Blk, 22 Speed Triple RS
I wanted to see if it was possible to reduce the ferocious heat coming off the back cylinder header hitting my right thigh at stop lights so I decided on an experiment to see if it was possible. I purchased a 1 foot by 6 foot piece of Nomex cloth from Amazon and cut a small piece to wrap the back header pipe outlet above the heat shield. I tucked the excess cloth behind the heat shield and held this scrap on with a SS exhaust wrap tie. I wasn't concerned with the look, just heat dissipation. Took the bike for about 60 miles through urban roads with some highway thrown in to make sure it wouldn't blow off. It stayed put all the way and back to home. Roast levels on the right inner thigh were much much lower, so I'm going to double-up the thickness (plenty of room behind the heat shield) and see if I can get it down to being a nonfactor for foot placement at stops during idle. After I determine total effectiveness (and how many layers it takes) I'll look at high temp adhesives as a method of permanently affixing the material. If I can get the heat down to tolerable on the back pipe then I'll treat all three pipes.
