JSHRAM
.060 Over
Help!
Added header (Viking), pipe, vacuum canister delete, RamAir kit and new map (TuneECU).
Bike idles well after it warms up (but doesn't until it is warm), but when you drive it it misses like it isn't firing on all cylinders, but all the plugs look good so if it is missing, it is doing it intermittently. Pops and stuff on decel, but that is likely the map. Map is from the TuneECU site for full Jardines, KN pods, so it should be close enough to make it run.
Talked to Hans and he said I must have a vacuum leak... ran it, sprayed WD40 all around the carbs and hoses, no difference so no vacuum leak. Checked plugs and connections for other wires they all seem good. Then I pulled the coil wires and they are very loose so I wiggled all of them and put them on and off and got some improvement in the ride (surprising). about to yank the tank one more time (getting quite proficient at this) and crimp every coil lead and reattach hoping that is it.
What else could I be missing that would cause it to miss so badly? I'm sure there is something dumb I did that I'm not getting...
I think the bike is beautiful with my mods (Ignore the Fram filter, I needed something and had that, it'll get it changed).. I'm very sad I can't ride it and I work away from home and was hoping I'd get this knocked out before I went full time (I'm home about 6 days a month now).. so, if I can't solve it, I'll need to give up and park it.. I know no one in Southern Utah or Vegas that could mess with it, do you?
Thanks!
John
Thanks!
John
