Find-a-flat II strikes again.
Baggage1
Turbocharged
NW Fl
2006 Rocket III
With almost 700 miles on my Riken Raptor I got screwed. Went to hop on and she was flat. Found the nearest distributor for Ride-on and got 2 bottles and unscrewed the offending sheetrock culprit. Put 14oz. of contents into the tire and added air, spun tire and heard a small leak get choked off at the throat. The distributor has a shop to die for and a modified tire machine and has several motorcycle projects going on in his garage. I now know where to get tires cause he sells and balances no questions asked.
Bob . . ya got a way with tires. Have you ever thought of installing a continental kit on that Rock? Might be a new fad
Ride-on, Fix-a-Flat, Enzite, and Viagra are all the same...artificial. I'll never again believe in such nonsensical derivatives.
The heart and soul of the Stop and Go tire repair kit : Stop & Go Replacement Mushroom Plugs : JC Whitney: Motorcycle Parts & Accessories
The mushroom plug is a major ease in tire repair. I very much advise a drop of vegetable oil (tic: trying to go green) on the head of the penetrating head. But you can as a last resort to dropping a drip from you oil cooler dip stic; expect no pain. The mushroom head will easily push through the plunge(r) entering the eruption with awesome ease. Provided you've reamed 'er out with raspy foreplay. There is a tool available if you've none of your own. Approximately 4 CO2 canisters will marginally inflate a darkside, to get you down to the next filler 'er up. Four will also do for a Metz.
HeR3tic I have had that kit in my bag since,"Find-a-flat 1" I've used a mushroom and rope plugs on 5 Metzlers. they do work but I wanted to give this stuff a shot. Took a 60mile test run and no leaks so far. Pig9r yes I do and it says SUCKER on it. Snuff as you know any Metz is disposable. boogerdave you know too well about my tires. How much is a pony tank? I'm looking into getting a settup like you have trailer wise just to tote the spare tire and all the junk to fix it or change it out.
Bob,
At the rate you get punctures you could become the poster boy for Ride on Sealant, like Jared is for Subway sandwiches!
You must have a big magnet in your ass.
Haaaaaa, That's funny. I must have one also. You would think that after I had already picked up every piece of crap in the road you would get through unscathed. I guess not.
