Final Drive...do it now!
Greasing the rear spline
When I read the stuff Warp writes I feel extra stupid.:(
And after I removed the rear tire and greased the bevel box with a synthetic grease, will it last until the next oil change? After reading all of the posts I went to the Honda store and bought the Molly paste for the next time.
pulled the bevel box of yesterday the drive shaft had the rusty look about it but it was still a bit tacky to touch, l was concerned about the other end but after reading the relative information I left it alone
this was supposed to have been done every tyre change l have my doubts
The 'every tyre change' was just a suggestion .. in the hope that the job will be remembered. Bit like every new tyre i throw in a bottle of injector cleaner ;)
Pulled bevel box off today to send to paint shop.
Getting it coloured as triumph should have done in the first place.
Was pleasantly surprised at the condition.
Lube at the end of shaft was still a little moist and in good quantity.
No obvious signs of wear after 50k.
Gotta pick up some Honda moly for reassembly, putting my new wheels and cobras front and rear back on :D
Red red wine, i mean rust
The dealer would NEVER pull the rear wheel off and lube the final drive as part of the pre delivery inspection. That's done at the factory when they put the final drive on the swing arm. I've never seen any brand bike I've been around that would. Lucky to get them to check the engine oil level these days!
I lubed mine at 7,000 miles when I replaced the rear tire. My lube was a light Blue color from the factory. I question if it's a Moly lube from the factory in the first place? I used Honda Moly60 paste. It's dark Grey in color. I've never seen a Moly lube that is Red in color? Looks like rust to me.
I bought my 08 R3touring in aug of last year with only 4500miles on it. The rear tire was REALLY squared off and about illegal. The bike came with a new Metz tire but I wanted to go to a larger tire (wider). Anyway,,,,no takers on the tire, so I mounted it and will proceed to demolish it in short order.
Now, the rest of the story....I had some spare time in the shop last week and was looking at the "bevel box" AKA final drive and said to myself, "well it's so easy to get at now, might as well do it"........and goooood that it did. I had to take a block of wood and hammer to separate the box from the control arm. The rust was unbelieveable....I think the dealer prep guy just put a smear of grease on the trannny side and then slid the assy together,,,there was NO sign of lube on the box coupler side. I'm assuming that this service is supposed to be done when they uncrate and assemble the bikes after shipping........but that leaves a LOT of room for error. FYI that pan in the last pic is the rust that came out of the final drive end,,,,I had just as much cleanup on the tranny side. I know some of you have said,,,,do it every time you take the rear tire off,,,,,and I'm a believer now!!!!
PS...this bike only has 7k on it now...barely broke in
Mine was the same at 10000 klms. The tyre shop said it appeared that no lube had been added during assembly and was coated in rust like yours.
Dang....I have never did anything to the final drive except change the oil.
My rear tire has been on the bike since 2007...Looks like I have a new project to do
Any tricks to doing the front and rear that might help an ol man out??
I'll be doing it by myself.
not really a big deal...
The box comes off fairly easily (although I had to help mine a little with a block of wood). Hopefully the rust situation is not as bad on yours. Going back together was a tad more difficult. I used a thin pick to push the preload spring up into the pocket in the box side and it slid together with no problem. I gather from some other posts that not all R3's have this preload spring between the box and the driveshaft. Without the spring I could see this being a bit more difficult. Maybe some others can help out with the differences since mine is a touring. I used a paste-like moly/graphite blend that GM specifically uses for slip yokes for lube on mine.
