Does this display make my bike look small?
Watsonian
.060 Over
Atlanta
Setting up an Android device to act as a display on my bike. Will replace stock display devices. Have a Bluetooth OBD connector hooked up and the software loaded on the tablet. Everything works great. Looks like I can also replace GPS with this setup as well. Looking for feedback on the appearance. I know this screams geek and I am ok with that because I am a major tech geek. Thinking that a 7 inch model might be better than this 10 inch model. I haven't done anything to mount it until I decide on the size that fits best. Thanks to my lovely wife for acting as hand model.
The 10" may be too big on an unfaired bike, especially one without a technological theme. Know what I mean?? No ABS, TC, ESA, fairing with power windshield etc., etc.
Will the GPS function work where there is no cell service?
Is it possible to create something as small as the satnav and be able to scroll between screens with say, speedo and rev counter superimposed? Just an idea!
My concerns would be weather, vibration (causing device breakage), visibility in bright light, battery life, and theft.
The weather and BRIGHT light would be a major concern to me. I've tried all sorts of modern gizmos over here and in summer - the sun makes normal plastic cases warp (especially in a transparent waterproof case - it's a green house) and forget seeing the screens. You could always couple it to a 12V supply for power. Theft - big issue here too.
Aesthetics are personal. Personally I like as little distraction as possible in my line of sight.
The tablet has a GPS chip in it so it performs like a regular GPS device with the proper software installed, which I have. The Torque OBD app I have installed provides displays for many different metrics such as speedo, tach, oil pressure / temp, coolant temp, MPG, miles to empty estimate, gear, battery voltage, etc. The device is protected in a hardened weather-proof case so I am not to worried about that. Power is pulled through the battery and run from the Eastern Beaver PC8. I can load all my music into it and play it through the bluetooth speakers in my helmet.
I do think the 10" model is a bit big and am thinking that something between a 4" and 7" model would work better. Thinking it would perhaps look better placed behind a fly screen. I only use the big windscreen for long trips. Something closer to the 3rd party digital displays I have seen installed on the Rockets perhaps would work better.
Thanks for the feedback from all. Hippo, I am not clear at all about what you think about it. Could you clarify your thoughts for me?
