Do I need a new clutch?
ahpd1992
.040 Over
Huntley, IL
So Im out for the first time this season as its sunny and in the 50's. I make my way to the local HD dealer that holds a M/C training class and I see one of the instructors tooling around on the course. I ride in and he tells me its OK to go ahead and practice on the course as the shops closed and none of the cones are out basically if I get hurt Il be considered a tresspasser and Im on my own as far as liability goes.
Now Ive been a motorcop for almost 10 years and Id much rather spend an hour riding a cone course and renewing my riding skills to start off the season so I started tooling around the course. The cones weren't out, but the markings were on the ground so I could see where I was supposed to go. After a few very shaky feeling figure eights I stop and start talking to the instructor. I know I cant turn quite as tightly as I can on my HD RK at work, but like I said Im trying to awaken my dormant riding skills.
So the instructor watches me and gives me some encouragement and I feel Im leaning and turning as tightly as the R3T is able to. He tells me to try his bike (a RK like mine at work) and right away Im tossing the bike around like a Shriner in a July 4th parade.
So Im feeling good, thank the instructor, and get on the Triumph to head home. CLick it in 1st start letting out the c l u t c h...it engages after its almost all the way out. It also feels like the bike's still not fully in gear and Im thinking Oh NO. I made it home I think only because I didnt use the clutch and power shifted. I stopped at a light after a couple miles and the bike wouldn't go until the lever was almost all the way out and even then it didn't feel like it was in gear.
Did I fry the clutch? For information in order to do those tight turns and cone weaves the technique used is to feather the clutch, steady throttle, and use the rear brake to control speed. I didnt push the bike real hard, but probably more than most people would. I looked in the owners manual and it appears you can adjust the cable, but I dont know if thats the problem. Ive never fried a clutch that wasnt on an HD police bike, I think I toasted mine, but how do I tell?
My guess is the extra clutch work while doing lots of turning of the handlebars loosened or stretched your cable a bit. Nothing to worry about just adjust it.
Do you have the service manual or a link to it? There is a description in it how to adjust the clutch and how much free play to have. If your clutch was fried I think it would be slipping while you are accelerating.
I am going to sound like an idiot but ok power shifting is shifting with out having to use the clutch I did not know the r3t could power shift
.......You can power shift any synchromesh transmission. What he means is a clutchless shift. Roll off the gas and at the same time change gears and then roll back on the gas. The slop in the gears and shafts and final drive allows the transmission to upshift or downshift without clutching.
When you adjust the freeplay, be sure to set it to the manual spec. Too tight and it will eat the lifter shaft in a few miles.
power shifting is actually syncronized shifting and can be done on pretty much any motorcycle with varying degrees of success.
place your toe under the shift lever and put a slight upward pressure on the lever. then blip the throttle off and at the same time upshift. the lever should shift into gear pretty smoothly and you throttle on normally just as if you were shifting using the clutch. Ive been shifting this way for about ten years and never have hurt my transmission. Its a skill that comes in handy when you need to shift in a hurry, or your clutch is messed up.
It wasnt accelerating after I let the clutch out like it still was out of gear. Like the clutch is still in, I have the owners manual but not a service manual. I dont have a link to one either
I think MikeM had some clutch issues on his R3T. You might shoot him a PM and see what went wrong with his. He had it fixed under warranty and so far it's been fine since the repair.
If you were to shut the bike off you should be able to shift through some of the gears while you are stationary. Shutting the bike off cuts the power to the clutch and would allow you to shift somewhat easier. If your clutch is hanging up while you have it pulled in it makes it almost impossible to shift, a very notchy feeling. IF, however, the bike is hard to shift or the tranny feels "wrong" with the engine off you may have a tranny issue and not a clutch problem. At that stage I would call the dealer and run it by him.
I got kicked out of a MC driver's license test in Omaha cause I kinda power slid around the cones (Sliding the back wheel, somewhat of a controlled burnout). I spent a lot of time in the vice principal's office in high school too. It's a good thing I got old..
Thanks for the links I will try and adjust the clutch tommorow. I hope that will do it and I will no longer attempt to ride the R3T like a police bike. Thats too slow, this bike likes things FAST
I think its fixed
I tightened up the clutch at the lever as much as I could and took the bike for a spin around the block. I think I got it tightened up enough, but it seems it was tighter before my "incident" so I guess Il hafta adjust it more from the bottom, and Im still trying to figure out how to do that as I cant get my fat fingers between the clutch cable and the radiator, and crash bars. Maybe my local mechanic can lend a hand, otherwise Im riding to the Triumph dealer this weekend.
Thanks for all of the help, I felt like I typed 911! You guys responded so fast thanks again
