WinsomeThrone49
R
2024 rocket 3r got left in the rain last night and the screen is now flickering in and out very quickly, especially when the throttle is applied or at idle. When the bike is off it is not as bad. Fix?
Check your battery terminals make sure they are tight, that fixed my problem when I had similar issue
My bad.
I realise now that he is referring to the battery terminal connections under the seat.
But anyway, the multi connector at the back of the display could also be a source of a poor connection due to water ingress.......potentially, but perhaps less likely if it's just rain as opposed to excessive use of a power washer.
The connections to remove the multi-display are on the each side just below the display unit.....two allen screws.
