Dakota Digital 2 1/16" guage
redrocket
Naples, FL
I'm thinking seriously about installing their 2 1/16" coolant temp/ oil pressure/ volt/ fuel level on my Rocket. They say their gauge accepts only anolog signals so which of their sensors do I need? When someone installs the Triumph fuel gauge is there a sensor that comes with the gauge as a kit or is there one already in there that we can plug into that sends an anolog signal. What about the coolant temp and oil pressure senders? Do I need to install theirs somewhere too. Their coolant sensor has to be tapped and screwed in somewhere and oil pressure can be had with an adapter plate before the oil filter. Any ideas or comments?
http://www.dakotadigital.com/index.cfm/ ... prd331.htm
I believe all of the stock sensors are analog. I'm not sure if they are identical to other sensors on the typically American market Dakota caters too.
Someone here has the full Dakota dash though, can't remember who. They had to do a lot of work with Dakota to get it working right.
It would be much easier if they just made an OBDII version since all of the data is already there at the ECU.
I'm quite sure he is speaking Vietnamese or something! :?
Native One
