Seany Standard Bore Joined Jul 10, 2026 Messages 2 Ride Triumph rocket 3 roadster Jul 10, 2026 #1 How do you remove the front coil pack on a rocket roadster
Kevin frazier Widowmaker! Joined Dec 22, 2018 Messages 8,425 Location Nashville Ride 2008 Triumph rocket 3 touring Jul 10, 2026 #2 Remove the 2 screws holding it on bracket, theyre under headstock, disconnect 2 wires and pull it out.
Jhortz .060 Over Joined Jan 2, 2024 Messages 113 Ride 2012 Rocket Roadster Jul 13, 2026 #3 Kevin frazier said: Remove the 2 screws holding it on bracket, theyre under headstock, disconnect 2 wires and pull it out. Click to expand... This^^^ It is actually easier than it looks. I remember seeing it and filling with dread, but five minutes later it was out and went back in just as easy.
Seany Standard Bore Joined Jul 10, 2026 Messages 2 Ride Triumph rocket 3 roadster Jul 18, 2026 #4 Kevin frazier said: Remove the 2 screws holding it on bracket, theyre under headstock, disconnect 2 wires and pull it out. Click to expand... Cheers buddy
warp9.9 Pocałuj mnie w dupę Joined Jun 10, 2007 Messages 11,524 Location Forest City Illinois Ride 07 Rocket Jul 19, 2026 #5 Seany said: Cheers buddy Click to expand... Don't put the plate back in it only holds wire connectors they will lay in there just like OEM. Just run the bolts back in without it. This makes it easier to check and crimp the low tension leads on the coil.
