A2-70 = 600mpa min yield Gr:304 Stainless Steel as per spec.
Don't get me wrong its just that "GR 8.8 or better" as I stated, will have a known and tested spec whilst stainless bolts can come from anywhere from places where Quality control around tensile strength might not be managed as it should be.
If your happy using those bolts good luck to you.
No need to be like that now, we all make mistakes. Hell I wrote down 1.25mm as the thread pitch instead of 1.0mm.
Hell if someone can educate me on what the 7 means / what the stock bolts' tensile strength is for certain, I'd be grateful and willing to learn. As you should too bro.
Going off the original point, but Google 'stainless steel bolt A2-70 tensile' and you will see that it is 700 Mpa tensile, everywhere. Not 600.
If you're (not your) going to use yield strength numbers (I'd imagine in an attempt to defame stainless in the eyes of the audience here), then you need to use the same property to rate your 8.8s, where the yield strength is also much lower than the tensile strength.
Also, if a stainless bolt is marked A2-70, then it has every bit as much of a chance of its tensile strength being 700Mpa as indicated, as a steel bolt marked 8.8 has of being 800MPa as indicated too.
Nobody said the stainless bolts were not marked.
If any bolt is NOT marked, then yes, as you say, their strength cannot be relied on, but the same goes for any bolt.
If they're 700 then I am suddenly grown strong. It is a piece of cake to twist those heads off
Exactly... and they have appeared to stand up to high power bikes, which is why one cannot say 8.8 bolts are the "minimum" spec to replace them with.
