tdragger
Here's a new twist on the old "Rocket won't start" issue.
I went out this morning to ride my 2006 Standard to work. Turn on the key, all lights come on and normal gauge sweep. Hit the starter, nothing. No joy. Lights stay on. The starter switch is just dead.
I think, oh s..t, not the ignition switch again. Can't be, I have the EB relay kit.
Kill switch? nope, it's in run position and I get the gauge sweep.
Clutch switch? mmmm...can't tell at this time. Possible culprit.
Sidestand switch? nope. put bike in neutral and no change.
Gear Position sensor? maybe but very unlikely. would require a bad sidestand switch in this scenario.
So, I slowly turn the bars to the right while punching the starter switch. nothing.
Turn back to the left and at about 15 deg left, the starter kicks in. WTF?? Bike starts right up. A few more degrees to the left and no joy.
This is starting to sound a lot like a bad ignition switch even though I still have gauges. Then I remember, I have the Rivco ignition switch relocation kit so the ignition switch is not on the steering head. Turning the bars wouldn't affect the ignition switch.
Clutch switch is starting to sound more like the problem.
On the left side of the steering head, the gauge wire harness wraps around and disappears under the frame to the connectors under the tank. Where the frame cover mounts, the harness cover rubs and has worn away. I'm beginning to think that the wiring to the clutch switch has broken and it only makes contact with a certain position of the bars. Sound possible?
I'm obviously getting power through the ignition switch, through the headlights and gauges. Are the other safety switches downstream of the gauges prior to powering the starter relay?
