CvSisinthehouse
Got a new rear tire and now the wheel doesn't slide over enough to allow the brake caliper to fit in. I see Albertaduke had this issue before but just had the wrong spacer. I put some smaller spacers in and tightened it down, put it in first gear and got the wheel spinning pretty quick, then backed the axle out some and wiggled the F out of it, pulling it to the differential side, no luck. I had greased up the splines. Is it possible it was too much grease and the grease has nowhere to go? Thanks for any help.
