Mittzy
The Hooligan - Just Doing Stuff
- Joined
- Aug 29, 2011
- Messages
- 8,546
- Location
- Brisbane, Australia
- Ride
- 2020 TFC #385, 2014 R3 Roadster 230hp (BRUTUS)
Loosen (wind inwards) the adjuster at the top end of the cable, undo the nut underneath the lever assy then push the pin out.
Once out the lever (2 pieces) will be free and able to be unhooked - re hook (attach) new lever and put the pin back in and fasten nut.
Re tension your clutch cable with the adjuster leaving 3mm play in the cable.
Repeat on right side.
The pic below shows the underside of the lever assy, the nut you need to undo is arrowed and the 2 piece lever is circled.
