Skip, when you say the exhaust end of the pipe, do you mean the exit of the mufflers?
There is no way the baffles will fit into the exhaust end of the mufflers on the R3T Jardines, they are way too wide there. Mine are installed in the muffler end of the crossover pipe. So, on the R3T with Jardines you do need to remove the mufflers to access the baffles.
Oh, and according to conversations with Big City Thunder, it doesn't matter which direction you install the baffles, they will work the same. I installed mine cone facing the rear as I didn't want the baffle any closer to the bend in the crossover than necessary. The way its installed on mine, the majority of the cone portion extends into the front of the muffler.
