RocketEd
Clutch switch? I assume you're well aware of this, but even in neutral you need to pull in the clutch. If I had no way to test them I would be bypassing both the clutch and kickstand switch.
Can you hear the fuel pump prime when you turn the key on?
What happens if you run 12V jumpers to the starter?
Have you tried to bump start it?
Just in case O'rielly's gave you the wrong starter relay, NAPA AR272 works in my Roadster. Is it possible to install jumpers to complete the circuit the relay not be?
