Cmdrklassen
.040 Over
While cruising on the highway for a couple of hours two days ago, I noticed the occasional backfire. it had been running fine for approx. 2 hours before this occurred. my rocket is mostly stock, the only performance related change I've done is remove the stock air plumbing and install the triple k & n's. My father and uncle own performance shops and say that you can change the intake system with no need to retune. only if you do exhaust change as well. They say the intake change will just allow the engine to breathe more and better. and if anything cause it to lean out a bit, not enrich it to cause backfiring issues.
