crashpete
Surprise, AZ
2012 Triumph Rocket 3 Roadster
Good or bad?
I don't know about that particular product. Although I do know that "racing Formula" may not necessarily be good for road use. Racing isn't always better. Sometimes it is less than what you want because it only has to last for less than 500 miles and it could be too thin.
There is a lot of big claims but what is the base product made from ie is it Lithium based and what anti seize products does it contain
does bicycles as well I don't know about a product the aimed at bicycle market as well but moly grease is generaly good for extreme pressure . looks like General purpose grease I guess
Directly off the Jar; Maxima waterproof grease is a multi-purpose extreme pressure grease made from Lithium stock which imparts superior high and low temperature characteristics and chemical stability. It's special load carrying additive system contains no environmentally undesirable lead or metals. A high tensile strength fibrous composition makes Maxima waterproof grease durable under heavy loads, resistant to mechanical breakdown and water wash out. It offers excellent rust an oxidation protection and is highly compatible with seals.
