The smaller DIN socket has a higher rating than the large cigarette lighter size. My Battery Tender came with the DIN lead standard, a cigarette plug would cost extra.. Lots of heated gear uses the DIN socket.
No, but need to move other wires out of way. Look for the blue tape
removed the left side panel and the only blue tape i saw was a thin strand up to the left above the oil filler cap but could do find a connector.....i must need longer fingers? lol
The wiring is already in place ready to plug into back of socket. It is identified by a bit of blue tape which you cut to release the wire / plug. All clear from the instructions. It is also permanently live so you can plug your trickle charger into it.
I am not seeing the connector (blue tape) under and to the right of the airbox. Are there items you need to remove to get to it? Hopefully not the entire airbox.
I found mine behind the back edge and just below the airbox. I had to root around the wires before I found the receptacle. I think it had blue tape around it. Happy fishing!
Old thread I know, I found mine above the airbox, plug sticking upwards to catch all sorts of crap & water, not much thought gone into taping this one. Admittedly it has dielectric grease on the end of the plug. You can see the blue tape if you zoom in & the plug is that rectangle bit above the tape. I've not pulled it out yet as I wanted to find my plug before ordering the Aux plug.
