Antifreeze for our Rockets
If it is leaking from the top bolt of the pump then it may be the little washer is either faulty or missing. If that is the case then you can undo the bolt, put some gasket goo sealant around the threads at the head of the bolt, and tighten it up to spec - then clean up excess sealant.
I already put some permatex around the head of the bolt but I cant see it leaking from there.
Im getting a few drops congealing under the water pump. I had the hose off to do a coolant change but cant see any tell tale dribbles coming from there either.
Im going to take the belly pan off again and try to see the drops forming.
Yeah. A little fuel change here. A little compression change there. Switch the direct injection for throttle bodies. Add a few spark plugs and voila - R3 engine.
With this much torque, it's not easy to distinguish from a Yanmar.
