wjb
Nitrous
- Joined
- Dec 16, 2019
- Messages
- 1,285
- Location
- California No Longer!
- Ride
- 2008 Rocket III Touring 2002 Bonneville America
My clutch has been giving me fits lately. It all started when both the clutch lifter shaft and lifter piece broke. Those parts have been replaced but then the clutch would not completely dis-engage and would drag some even with the clutch lever pulled in all the way, and there was also no way to get the required 2 to 3MM free play. No amount of adjusting would cure the problem.
I had a washer left over from the repair that I had accidently left out but didn't think that could be the problem because it would only fit on the bottom part of the lifter piece and should not affect the operation of the clutch. (in my opinion)
So today I opened up the engine again to inspect the clutch and install the washer just in case it was needed and when I removed the clutch pressure plate I noticed that the wavy washer had fallen in between the pressure plate and the top clutch disk. So I am thinking that this was the problem of not getting correct clutch function.
Two questions:
First, do you think the out of place wavy washer is why I didn't get full clutch function?
Secondly, are both washers (regular and wavy) necessary for the clutch to operate correctly? I have a hard time thinking that they are, but don't see why Triumph would go to the trouble and expense of including them if they were not necessary.
The wavy washer was deformed when I tightened down the pressure plate so if it is needed I will have to order one.
Two questions:
