I asked that question of a dealer a while back. Simple answer is no. Probably cheaper to buy a newer bike with it fitted, which is exactly what I did. Stretch yourself, it's worth it. Or you could practice Cadence braking.
I won't go that extreme had her since 07 and don't plan on getting rid of her
Maybe I'll see about adding a tension spring to the pedal and see if that helps? I'm pretty used to using her softly, but when adrenaline kicks in, can't help but to over press
I had the same issue with my 06 R3... I now have a 11 R3R and the ABS makes a huge difference... You may want to try this system... It "should" work on your R3 and it has gotten great reviews...
