Mongler07
Turbocharged
Ever since I have had this rocket III it has had the following issue. It can sometimes pop into neutral from 2nd gear only when I'm giving her the beans, if I make sure I pulled back as hard as I should when shifting with my foot it usually did not happen. I suspect that its damage from when it was dropped? Otherwise all gears and everything works great. Usually it is a little picky about revving it up to down shift into 1st otherwise it drops into neutral.
The new issue now is that it under load will drop out of 2nd when i ride 2 up and it keeps coming out if I had downshifted into it. But upshifting has the same results as before (only happens if i go WOT at high revs if i dont hold back the shifter).
I dont think it's the detent spring, i have the clutch cable and arm adjusted correctly, and when I had the cover off the clutch actuator pin was in great shape.
What's going on? Any suggestions?
It's difficult and or dangerous to ride like that. Wife and i did 2 up in the canyons here in deer creek over to foxton and it became sketchy as I use 2nd quite often in back roads and switchbacks.
