What is Reset ISCV?
raytracer
.040 Over
In Tuneboy diagnostics, sensors tab? I assume it is Idle stepper control valve? What is the result of resetting this? THe manual is kind of vague.
I guess I dont have that manual - my owners handbook doesnt have that many pages in it!
Thanks for bearing with me and pointing out stuff I'm sure you've pointed out hundreds of times before! :wink:
Got the manual - a little over my head. Still not sure if it (ISCV) is something I need to reset after modifying a tune. Also, the triumph method of resetting adaptives (not the 12 min tune) states that the bike must be running at temperature. Is it the same for using the reset adaptive within tuneboy?
From what I understand emailing with Wayne, you only need to hit the reset adapt after downloading a completely new tune - it is not necessary when making modifications to the same tune
Also, I believe you can hit reset adapt after loading a new tune, then start your bike - but let it idle for a while so the bike can adapt to the new tune
I would not reset the ISCV if you're just basically downloading or modifying a tune
Anyone want to confirm or deny any of this?
