Using a Motorcycle Jack
I took a pic of the hamster bedding pad I use to distribute the weight evenly across the bottom of the casing. It's just compressed woodshavings from a pet store.. I place two pallets with the jack assembly in between and drive up and over the plywood side, then turn the pad over and jack the machine up. I strap to the ends of the pallets for stability. For oil change type maintenance, I just remove the jack assembly once the bike is on the two pallets. :)
