oakville
I have been having problems with stumbling ar low throttle positions. Figured it was a TPS. Tested and adjusted and things got better only to get worse again over time. Checked everything including all connections and pinching of wiring harness and again all seemed good. Things got worse again. Removed TPS today as it was variably getting better then worse then better and decided it must be wet. I was right it was soaked. Not with water though. Gas. The TPS was soaked with gas. This was causing it to read incorrectly and the ecu was fueling incorrectly. I reinserted the TPS after letting it air out for 2 hours and filled it with dielectric grease to try and prevent this from happening again.
Can anyone think of a reason for the gas filling up the TPS? I can't see where it might have come from.
Any assistance is appreciated.
