biker1059
Turbocharged
Longview, TX
Rocket GT
Have an 05 that Im about to put TORS on with the cat box, I did a search and pulled up nothing. Does anyone have this setup? Does Triumph have a tune for this setup? Planning on adding the bypass later, daughter in college, and know I'll need a tune for that. I can also see a tuneboy in my future but first things first. Any input is appriciated.
Ya, there's a map for it. For an 05, it should be aftermarket pipes without cat. Most of the bikes had an empty cat box back then, ergo the term without cat.
If you were doing the bypass at the same time, it would be aftermarket pipes with cat box removed.
Won't be very loud with the cat box still installed and very little performance gain either. Most of the gain is from the cat bypass not the TORs.
Thats very true, i tried it and didnt find it worth while til i got the bypass pipe.. then it woke up big time.. :)
be ready for some popping on deceleration though... not always pleasant.
