RoadVenture
.060 Over
- Joined
- Sep 18, 2007
- Messages
- 186
Okay, lets' test the technical knowledge and experience here again.......
Who among you has a source for aftermarket sparkplug boots and cables? My reason for asking is this. During the weekend I was changing sparkplugs and discovered that the rear sparkplug boot was apparently buggerd up at some point and is not making good contact with the sparkplug terminal. All the other five boots are good, but the last one just doesn't hold onto the plug like it should.
First: is there any way to fix this problem short of replacing the boot?
Second: if the boot must be replaced is there an aftermarket source?
Before you say it, I know I can replace the boot with a Triumph OEM part. The problem with that is that Triumph sells six boots as a set for $170. I would like to avoid replacing six boots because one is buggered up.
Thanks!
Thanks!
