tdragger
Ok, folks. Back again with my starting issues.
Background: New Scorpion Battery (< 6 mths), upgraded starter motor (1.4kw Denso), upgraded negative battery cable, relocated ignition switch to left side (aux socket position)
Symptoms: On occasion when I get on the bike, turn the key on, wait for the sweep, sidestand up, clutch pulled, and hit the starter, the lights go out and there's a noticeable click/clunk from down under where the starter is. To me is sounds like the solenoid doing its thing. Unfortunately, no joy with the starter turning.
If I let the clutch out with in gear, I can rock back and forth a little, pull the clutch and hit the starter and everything is fine. It fires right up like there's nothing wrong. If the bike is in neutral, it will not affect the start. It's almost like the drivetrain needs to turn just a bit to get some contact made so that it will start.
Tests/Actions so far:
Since I could rock the bike a little and get contact made, I thought I'd pull the gear position sensor. I've never looked at it before. Here's what I found:
It had a bit of grease on it that I cleaned off. My question to the group is whether this gps looks normal or not. The groove, particularly near the 1st gear position seems to be quite worn. Could this be my problem?
- Checked the engine off switch (kill switch) just in case.
- Cleaned and checked condition of negative battery cable.
- Pulled, cleaned and reinstalled the crank position sensor.
- Pulled 1.4kw starter and put old OEM starter (1.2kw) back on.
- Pulled and bypassed clutch switch.
