1olbull
Riding Motor Since 1950
Water Displacement 40th formula is a corrosion preventative...not really a solvent or a lubricant....and if any of those ladies need water displaced from their naughty bits then they are probably too loose for my liking...![]()
From Googlefoo:
WD-40 isn't actually a true lubricant. WD stands for "water displacing" and its main use is as a solvent or rust dissolver. ... But depending on what you're working with, you should probably follow up WD-40 with use of a true lubricant such as one based on silicone, grease, Teflon, or graphite.
