Sidecar Flip
A couple of things:
Tomo is right. The spray on stuff works. I get it at school. It's not sold in any store I've ever seen. It's a jobber item.
Don't use regular petroleum based grease on the pads. The rubber puck seals don't tolerate regular grease, however, you can get brake freindly grease at Murrays or PEP Boys.
Another good alternative is di-electric grease which won't damage the rubber brake components.
Finally, if a 1500 psi pressure washer could force any dirt past your puck seals, they'd be leaking brake fluid long before you washed them. I probably shouldn't say this, but my pressure washer is 3500 psi @185 degrees and Iv'e never had a problem. Of course I don't use a zero degree tip which you can cut a 2x4 with and peel paint real quick like. I use a 30 degree tip and stand back a little.
Pressure washers are like airless spray outfits. If you really knew how dangerous they were, you'd have the utmost respect for them. I know a fella who had to have his arm amputated below the elbow from an injection injury from a pressure washer.
