small light in headlight
sixpack
New Brunswick Canada
I installed the EB kit , but would like to replace the little orginal lights in the headlight,,, where do I get the power for these lights since I cut the wires??? thanks :confused:
You can use the left over OEM plug and wire it back to the position lights. Just splice in a wire from the left to right bowls and plug it back into the harness. If memory serves the black wire is ground to those lights so you'll need to ground them as well. Easy.:D
The black and yellow wires are what you need to run the pilot/parking lights
