MtlSteve
.040 Over
- Joined
- Jan 7, 2024
- Messages
- 59
- Ride
- 2014 R3T
in inspection they found a loose tank bolt. PO or dealer was doing work, lost the correct bolts and just used what they had. Bolts that were too long. My rapid fix was add a pile of washers. Brought her back, was good for the inspection sticker. BIG SHOUT OUT TO Sensfan for lending me his stock pipes, this guy would have found the non compliant "off rod use" stickers for sure. TORS are back on and the tank has correct length botts, HEX HEAD 10mm, NOT TORX, that head got damaged trying to tighten down (the threads were maangled, re-tapped and are torqued to spec, 11NM. Let the weather change soon. Reason for the trailer.... it snowed
