Sat nav connection ?
RooK
Devon, Alberta, Canada
'06 RIII
Rocket Sprocket,
Be advised that fuse 3 is not switched and is live at all times.
Fuse 3 supplies power to the PURPLE wire
Is it the accessory fuse for:
--Instrument accessory
--Power socket (connector located behind cover)
--Heated grips
--Clock
Besides the connector for the power socket, the other 2 connectors are located under the tank. All the connectors are identified with blue tape.
Keep in mind that there is another purple wire that ends up (I think) under there as well for the foglights (fuse #1)
I've connected my comms/nav kit to the spare wires that are meant for the accessory socket on the left hand side of the bike, about four inches forward of your left knee. It's not a switched supply though. It's on fuse 3 as mtcm101 says above. Using crimped blade connectors and then wrapping the connection in self-ammalgamating tape has created a setup that I can remove easily in the future and is weather proof.
Cheers,
Garan.
I connected my Zumo 550 to the pilot lamp in the left headlight. It includes the XM receiver. There is room to get the power lead in the grommet in that light.
This is a switched source and if you want to power without the engine running, you can turm the switch fully CCW past the fork lock position. Only the tail light, the two pilot lamps, and the GPS (with XM Rx) will come on.
Tom
Rocket Sprocket said:
Thanks for the reply's guys, and the winner is the one in the head lamp,
because I don't wana have to feed a cable up to the handle bars, I hate effort :wink:
Sometimes the easy option is the best option :lol: :lol: :lol: :lol: :lol: :lol: :wink:
PS - What do I win
