same problem as some
can start growing my hair back
thanks all TPS that was the problem back to a big **** eatin grin love my bike just do not like when its not running good almost 50,000 miles on it and with the new TPS she runs great
You jinxed me! My bike was running fine when I put it away but yesterday started to miss at idle and run rough when taking off from a stop . I hooked my my OBDII scanner and predictably got a TPS code, P0223 "throttle position sensor B circuit high output". I just ordered the cable too so I could use Tune ECU. Guess I won't need to wait for that to come in. :mad:
I have a dealer about 5 miles away. I'll see how much they want and when they can get it. Otherwise I guess it's Bike Bandit.
low RPM coughing back firing going down the highway or just crusing down the road if I just let off a little I get hesitation and coughing ok there has been a lot of great info on this site and I have tried some of it and I just want to call it quits but I love my bike tried the PCV and when john at dyno solutions in Danbury CT installed it and once installed and map in it still did the same thing so on the PC V u can check each cylinder individual and the load numbers were jumping all over when tried to give it a little fuel so pulled it back out brought the bike home saw on the site that someone posted it could be the 12v connectors on the coils not that did the plugs no fuel filter no checked for vacuum leaks I NEED HELP does any on live near Waterbury CT THAT KNOWS WHAT THERE DOIN CAUSE LIBBYS in new haven does not no to much and Branchville just lost there teck HELP PLEASE[/QUOTE
Riverside Triumph | Triumph Motorcycles
My dealer just went out of business, i heard good things about Riverside Triumph,Somerville ,Mass. I think i'm going to need the Eastern Beaver,i've been having trouble with the ignition switch. I know it's a haul but good dealers are far and few between. Mike from Corn Pie Classics is said to know his Triumphs also and may be a little closer to you.
Motorcycle Repair, Service, Sales and Parts Located In Western Massachusetts
omg going crazzzzy
ok I listened TPS OK put one in adjusted with a volt meter to .60 volts ran awesome was so very happy two weeks about 400 miles then it started running like **** seemed like the TPS again so I checked the volt thinking that they might have moved and the volts jumped to 1.03 volts and so I tried to adjust it down and it would not go down .60 volts and I can not get it back down does any body have a thought on what it might be need help I need my bike back
When installing the TPS are you using tuneing software? You need to install it while d performing the full ISCV reset or you will have no way to retract the idle stepper motor so you can set the TPS .60 volts at closed throttle position. Also wjile your at it lubricate the springe netween the throttle bodies and under the boot on the idle stepper motor if the shaft gets to dry and gunged up it will stick and the throttle wile not close or adjust as the sensor readings require it to.
