Please help, I have a 06 classic. Yesterday I rode it to work in the morning and it started great, just like always. At noon, I went to go for lunch and when I turned the key, the gauges go through the motions, but when I hit the starter button, I get nothing but a very faint click. I tried jumping it and same results. I pulled the battery out and tested it and it is good. Is there a relay that could be bad or am I looking at a wiring harness issue???
Any help would be appreciated, the nearest dealer is about 200 miles away.
From what some of you have described, I believe it is the ignition switch. I have checked the battery and it is holding a good charge and puts out 13.8volts. I will definitely check all of the connections first, but it sounds like the switch. I do have the relocation mod done to my switch so it is below my left leg. I can't remember how much of a pain is was to get it out of there, but I will pull it out and take a look at it. I will also check out the bypass so this does not happen again.
Thanks for your help, I will post again when I figure out this problem. It is a bummer that we only get like 10 decent riding days in ND each year and I will be fixing my bike on a few of them :-(
