ThaiRocket3
Standard Bore
- Joined
- Dec 12, 2022
- Messages
- 10
- Ride
- Rocket 3 GT, Tiger 800, Vulcan 650 S, Honda Rebel
I am having really good time with DNA filter. Made in Greece, make sure to get rid of oxygen sensor thoughI hope it is ok to revisit an older thread. I just put on some Vandemon pipes and I am going for a remap/tune. Should I keep my stock air filter or go with something different like these?
Sprint Filter P08 Triumph Rocket 3 GT/GT221 and R/R221(19-22)
$125
Sprint Filter P08 F1-85 Triumph Rocket 3 GT/GT221 and R/R221(19-22)
$300
DNA Triumph Rocket 3 Air Filter (2019+)
$130
Thanks!
Oh, oh, this is the first I’ve heard of an ox sens delete. Just plug the hole & stash the sensor?I am having really good time with DNA filter. Made in Greece, make sure to get rid of oxygen sensor though
just disconnect after you remove the plastic panel on right side, and then of course disable it in penner tune as well (and reflash of course lol)Oh, oh, this is the first I’ve heard of an ox sens delete. Just plug the hole & stash the sensor?
Mr Penner said its not necessary to tune after disabling/deleting o2 sensorLooks like stock O2 sensor is a narrowband.
There is no meaningful adaptation occuring to compensate for more air flow. At best, only the archaic long term trims based on part throttle use and a model of fueling required (when equipped with the restrictive stock filter).
Sprint are less than ideal, stick to K&N or DNA if you want air that's actually filtered. Sprint race line filters can flow the most, at the expense of the largest particle size filtering (regardless of their marketing). There are so many pictures of sportbike guys using them that had dirt/crud in the air box using a Sprint I won't bother linking. It's trivial to find.
Is a retune mandatory? No, not entirely necessary to simple ride the bike.
Should a retune with O2 disabled be done? Yes, absolutely because the fueling will be incorrect without fail after swapping.
Running and running right are not the same. The bike will run with a rubbish tune but it won't be right.
