RockOn
Turbocharged
- Joined
- Feb 22, 2018
- Messages
- 585
- Location
- Escondido, CA
- Ride
- 2006 R3 Classic, 2008 R3T, 2009 Harley Ultra
I've dismounted the rear wheel on my '06 Classic in order to replace the worn out tire. The two bearings on the drive side, one on top of the other, spin freely. The bearing on the brake rotor side does not spin freely. I repacked the bearing with synthetic grease in hopes it might break free and spin but the inner race still wouldn't budge. In an attempt to get the race moving I wedged a tapered knife blade into the race and with much force I can spin the race 360 degrees in both directions. Then with a flashlight I noticed the axle sleeve/spacer running through the wheel turns with the race as I turn it. This sleeve does not turn when I turn the bearings on the opposite end of the sleeve, the drive side. So, I know from forum searches this is not an uncommon occurrence. Apparently, most guys who encounter this problem replace the bearing. I see several different theories about why this happens to this bearing: "Torque spec of 81 ft. lbs. is too high on the axle nut", for just one example. Not knowing squat about bearings or how that sleeve through the wheel should operate in conjunction with the bearings, I'd appreciate any thoughts/suggestions/experience about this situation. I hesitate to remove the bearing and replace with a new one, especially after reading posts about how much difficulty members have had doing it. Is a new bearing going to operate correctly? For how long? I ask because many members apparently discover their frozen bearing operates perfectly after it is removed. Why bother replacing with a new one if the old one operates perfectly when out of the wheel? I am confused by this. Thoughts please. Thanks.
