raising idle speed
hogweed
Warminster Wilts .UK
Triumph Rocket III 2004
Do i need to reset the TPS when altering the idle speeds with tuneECU,will encounter any problems by altering the speed?Thanks
Raising it to around 950 is a good idea..less stalling risk, but importantly it raises the oil flow( isn't good at lower revs)
do i still need to Reset Adaption when doing the Adjust ISCV test to check measurments even if i havnt adjusted anything?
It now seems to have developed another buggy little problem after raising the idle speed in that the engine has cut out due to low rpm like pulling in the clutch and closing the throttle quick coming to a stop(did this once)
I've since adjusted the TPS from .61 up to .62 and the stepper motor .72v up to .74v which seemed to make the motor a bit crisper but it has cut out again a couple of times as before.
I have noticed that if you cut the throttle and pull in the clutch the engine revs go down to about 400rpm on the rev counter then after about 5 to 10 secs approx the revs rise to what i set them too.
Anyone got any ideas ?thanks
Today i set it at 950rpm TPS .60 stepper .72v, the proof of the pudding will be my ride tomorrow,cheers
