Wadejesu
This TFC will fool you on how fast you traveling, Wonder what is best Radar Detector out there. Last Radar anything I used was back in 1969 it had vacuum tubes.
I guess it depends on where you live. I have radar detectors in both cars and most often see Ka band. Occasionally Laser but not as often.
I've used both Valentine 1 and Escort on a number of bikes. Both work well if set up properly. A couple of the newer Escorts have the directional arrows like the V1, but don't bother looking at those until you scrub off some speed. You either need connection to ear plugs or less reliable visual enhancement. Mounted on the bars it will be out of your line of site and without an audio alert in your helmet you'll likely never see or hear it.
As noted, common sense will be the biggest tool in your ticket avoidance kit. When out of city traffic, scan far ahead, if you're the only vehicle traveling in your direction you're very vulnerable. Laser and instant on Ka will nail you before you can react, even with the best detector. A well traveled road is safer as speed traps will likely be shooting ahead of you and a good detector will give you plenty of advance notice. Having somebody blow by you at a high rate of speed is the safest invitation for some fun. Give them a bit of distance and they will be the one scooped up.
