pjl52
.040 Over
Can't say as I've noticed anything like that other than the slight vibration from the flywheel. As for speed cruising, I did a run a few months back where I held 150+ km/h for over 2 hours without any drama. Acceleration had to be reeled in as I was riding in back behind a GL1800 and a VN900, but had no issue getting up to speed or passing.
That being said, nobody would deny that the rear suspension is fairly firm, how rough are the roads where you are? I could see that causing a bit of a hum.
Being rural the roads vary from rough to bloody disgusting, however there are some that are capable of handling a vehicle at illegal speeds.
Have you had your initial service done? And if so, did they balance the throttle bodies? Probably not since I don't think that's called for at the first service. I do know that my R3T ran much smoother after the 10K service. That would be the first thing I'd check. Since you're pushing pistons the size of coffee cans up and down a throttle body imbalance will likely cause a noticeable vibration.
Had my first service done (850km) the mechanic said that he balanced the throttle bodies at the time.
No that is not normal. 120 kph is only about 75 mph and I wouldn't even call that fast. Mine will run over 100mph (160 kph) all day with no problems. I have been well over 100 mph several times with plenty of power left. IMHO There is something wrong with your bike take it to a good dealer before you have a catastrophic failure.
I am of the same opinion, I don't expect the bike to be as smooth as a UJM but I did think that it would be a bit better than it is. Back to the dealer, I think if only I could find another to compare that may go some way to alieving my fears.
Thanks for all the comments.
Peter
